Change my Revit license from student to commerical?
pboutany
pboutany
Hi all,
When I downloaded Revit initially, I used my student license as we were not actually now my firm actually is using Revit, we have bought a commercial license, how do I change the license?
Thanks in advance
dferreira-blackwell
open Revit--> on top click your user name dropdown arrow, select menage license.
pboutany
yeah, when I do this, then it goes "Change license" so I click on it and it just closes Revit. Doesn't open any other windows or webpage, just exits revit
dferreira-blackwell
well try using this link: if don't work I would suggest contacting customer care:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/screencast/Main/Details/d7d...
DarrenP
you can try resetting the license: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/simplecontent/content/autodesk-s...
DarrenP
ennujozlagam
you can refer to this LINK and see if helps. thanks
Jamhmer_Oc
Have you tried here?
You enter and then you go to manage license and you could change.
Jamhmer Oc
