Cannot link dwg - solution
Karol_Piroska
Advisor Advisor
Karol_Piroska
I realised today that you cannot link dwg version 2018 to Revit 2017 (I haven't tried different combinations). I was getting error messages: "some elements were lost during import..." and then "import detected no valid elements in model space...". I tried all possible solutions I found on forums and none worked. Then I tried to save it back to lower dwg version and it works.
Maybe it will help someone in the future.
Kelsey.S
Autodesk Support
Autodesk Support
Hi @Karol_Piroska,
Thanks for sharing your findings with the Revit community! I'm sure it will help other Revit Professionals like yourself who may experience a similar issue.
I did locate the below article that seems to relate to your issue. I will be sure to update the article and make note of the need for DWG and Revit version compatibility.
Revit - Cannot link DWG - Import detected no valid elements
You might consider selecting "Accept as Solution" so that other members of our community can easily find your post and benefit from it.
Kelsey Skaug
Autodesk Technical Support
