Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Can't see Material Pattern
1 REPLY 1
Josh.ua
175 Views, 1 Reply
I created a Foundation Slab and PCC blinding both using Structutal Foundation Slab command. In a sectional view I want to see the cut pattern of PCC blinding only and want the foundation slab above to have no cut pattern. I tried giving different Material to both slabs but the cut pattern is only visible in Detail level :Fine. The problem then is that the reinforcement in the foundation slab becomes visible as solid. I want to see the reinforcement as lines.
I've attached the file and an image here. The problem is in Section 1. I'm using Revit 2015.
1 REPLY 1
in reply to: Josh.ua
Edit the foundation slab type and give it a pattern for Coarse Scale cut pattern.
You can also keep the view as Fine and VGO the reinforcement categories to Coarse.
Forma Design Contest
Technology Administrators
