Can I edit the circle leader (open dot leader)
rdolphins1427
rdolphins1427
Is there a way to remove or edit the "out of the box" open dot leader in revit? I do not understand why programmers would have the leader line extend into the circle, this obstructs anything that you are trying to call out.
For example, we would like to use this open dot leader to call out horizontal rebar but the leader line extends into the circle which would obstruct the item we are trying to leader too......
Any help would be appreciated!
(Please see attachment for clarity)
L.Maas
As far as I know this is not possible. The options to control the leaders are very limited.
The only things you could do is using 'free end' to place the leader at a slight more convenient location (more work)
The other thing that could help is to use a graphics overrides to make the leader a lighter color.
But that is as far as you can take it
Louis
Please mention Revit version, especially when uploading Revit files.
rdolphins1427
Who can i contact at Autodesk for suggestions? There has to be a "place" where users can give suggestions for the programmers. Do you know of any?
L.Maas
Yes here http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Louis
okapawal
You can follow prerelease develeopment and suggest a feature request at the Beta forum
https://beta.autodesk.com/home.html
Waldemar Okapa
Sr Product Owner
PhilipHD9LWH
1O years later and Revit still haven't fixed this.
