calculated value formula
A_MAQ
Advisor Advisor
Message 1 of 14
A_MAQ
Hi all,
i trying to use formula in schedule properties parameter
what i want is creating a specific parameter that read a value from the two another parameters
for example: when i create the foundation schedule , i want to define a depth parameter for scheduling
but as you know Mat foundation depth is not the same parameter as isolating footing depth parameter
so i want to create one parameter and give it a name of foundation depth and read the two values
how can i do that?
thanks
Autodesk Expert Elite
Replies (13)
Message 2 of 14
GatisM
not sure if i understood what exactly you want, but did you try "combine parameter" option?
Message 3 of 14
Karol_Piroska
All you need is a shared parameter for the pad footing (let's say pad footing thickness) and then you can list this in the schedule. Then you can change the Foundation Thickness (associated with strip) to Strip Foundation Thickness so that noone willl be confused.
Message 4 of 14
A_MAQ
this is a clarification
Message 5 of 14
Karol_Piroska
ah ok. If you are using Revit 2017 you can simply combine them with the new "combine button". I dont think it's possibly in lower versions (I might be wrong).
Message 6 of 14
A_MAQ
that's it
i want to do that in revit 2014
Message 7 of 14
L.Maas
If you want to do concatenation, combining two or more strings (or values as strings) in a single field you could do that with Dynamo. In there you can read values from parameters, combine the values together and push them back into another (new) parameter.
On the Revit forum (HERE), a discussion about this.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 8 of 14
A_MAQ
so it can not be done with 2014 without dynamo
i think it can be made be formula
but how can it will be made this what i want actually
Message 9 of 14
GatisM
I have rvt 2017 at first i simulate your situation, add to loadable family parameter "foundation thickness experimental" wich are not include in system family. Than i add field with if statement (i operate with parameter "width" but it could any anathor parameter), of course you must check every time if your formula work correct. See picture.
If helpd please mark as a solution.
Message 10 of 14
A_MAQ
that is not what i meant
i am talking about revit 2014
Message 11 of 14
GatisM
hmm. It must work for 2017 also for 2014. It is not related with "combine parameters" option.
Message 12 of 14
A_MAQ
it's great ,but it needs some work also
i do not want the other parameters available in the schedule
Message 13 of 14
GatisM
additional parameters you can hide with "hidden field" in formatting tab.
Message 14 of 14
A_MAQ
that is great
