Bring in Ebm files to Revit
Jerrie.gengEB825
Jerrie.gengEB825
Hi, there,
Any one know how to Convert a Catmatic ebrowser file and bring into Revit to use? thanks a lot for any suggestions.
Jerrie
ArmanMargaryan
I'm not familiar with this program, but I think it is possible to export an IFC file․
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
Linkedin | Facebook
Revit Structure Certified Professional
ennujozlagam
try to convert to another file format that you can import to revit or autocad then to revit? thanks
https://www.file-extension.info/format/ebm
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Jerrie.gengEB825
Hi, thanks for your posts. Just to let everyone know. I contacted the software supplier, there is no way to bring in EBM file to Revit. Have to export the other format from the original model.
