Bracing Representation Line
13lemartinez
13lemartinez
Is there a way to change the location of the representation line for bracing between columns?  For a project I am working on, it shows the line outside the building, but I would like for it to be show in the inside of the building.
I looked in the link below, but there was nothing that did what I wanted it to do.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2014/ENU/Revit/f....
gevanKGYB4
Can you provide some pictures as an example?
13lemartinez
The green line is the representation line, placed by Revit.  I want it to show where the red line (I sketched) is.
gevanKGYB4
I am sorry but it is not very helpful. Could you click on that line and take a larger snip showing your properties when you click on the line?
You could cover portions of the snip image that you don't want to share.
13lemartinez
