Beams in beam system not selectable
z
A_MAQ
Hi @Anonymous,
welcome to community
could you elaborate more ?
Autodesk Expert Elite
aleksei.tkachenko
Hello
Try to uncheck "Select Pinned Elements" in the lower right corner of Revit window.
You need to either remove the beam system or unpin the beam you want to select.
Sahay_R
In the Modify tab - click the Select drop down below the Modify button. Make sure that all the options are checked. That will also allow you select pinned objects.
Rina Sahay
Revit Architecture Certified Professional
