Beams and Column without geometric representation in any view (2D and 3D)
[Revit 2020 - Windows 64 bit)
I was working in a steel structure, had already placed all columns and beams and was working on the detailing of the connections. On the next day, when i opened my project, some beams and columns representations became a line. If I change the profile, the representation returns. img 1.PNGimg 2.PNGimg 3.PNG
How can i solve this problem, permanently? I need to submit the project to a client but I can't get a full view of the structure in renders or at Autodesk Viewer.
KrisAribal
Have you check the beam family?
it's visibility settings with other beams?
vick1z
Can I ask question what is your LOD requirement for this project.
The LOD is set at fine. Unfortunately this isn't the problem.
The problem happens with any beam family, I already used OOTB and beam family that I created.
Where I can ajust the visibilyty settings with other beam?
