When using a Beam/Column connection or Beam/Beam connection Revit shows a gap between the two members in plan and then you can adjust how it looks in section with "Change Reference" and "Coping".
However when doing a Beam/Beam connection one of the Beams is typically at a lower elevation because it has joists on it and when you try to do a Beam/Beam connection with beams at two different heights Revit no longer puts the gap where they are joining. Doing a manual adjustment to make them look right in plan is fine unless you are showing an elevation and then you have a gap between your Beams instead of showing them connecting.
Does anyone have a solution or a work around to fix both Plan and Elevation?
Solved by Jason.P. Go to Solution.
Have you tried using your "z offset value" instead of your "start and end level offset" in your beam properties. I find if I use the start and end offset there is no gap, but if I use my z offset there is a gap. Z offset will also work better with your anaylical model.
