Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Beam System shenanigans
2 REPLIES 2
itsme.mozzarella
505 Views, 2 Replies
I'm having an issue with the functionality of the Beam System. I've made a boundry in which I want 14 (Fixed Number) beams placed evenly, starting and ending with a beam, not with empty air. Why is it that Revit 2019, when told to place those beams evenly in a specified boundry, places them as seen in the screenshot?
Tags (2)
2 REPLIES 2
The beam system tool is meant for placing the secondary beams (joists/pulins) between beams.
Not for the primary beams that go column to column. So it doesn't place the first and last beam.
AJ.
AS You can see from the beam system icon itself, it will place blue highlighted beams not the end ones.
