Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Beam schedule
3 REPLIES 3
francfiles
1248 Views, 3 Replies
Beam schedule
Is it possible to creat a sbeam schedule as shown in the attached jpg file? it's a screen shot from autocad.
Thank you!
3 REPLIES 3
Tom_Kunsman
in reply to: francfiles
Yes it would be possibile. Just a matter of adding the correct fields in a schedule. The Bottom Bars and Top Bars fields could be everything from "dumb" text to actual elements from the model I think. I am now just getting into modeling rebar in a project.
The image can also be done with actual images from your computer.
You might have to add some Shared Parameters to get everything to look the way it did in Autocad, but can't see any reasons why you coul not replicate this in Revit.
francfiles
in reply to: Tom_Kunsman
Thank you! would you know if there are any literature here that can help me learn how to do this kind of schedule especially on how to show the rebar graphcics?
Thank you and I really appreciate your help!
Tom_Kunsman
You should be able to do the schedule itself fairly easy in Revit. The graphic portion that would take some time and I have not done that yet. My guess is that you would need to create some JPG files of the different type of bars and then simply add to the schedule.
Forma Design Contest
