Beam/Joist Offset Elevations
mhaschakHSE
mhaschakHSE
Is there a way to essentially pin the elevations of beams/joists? I have all my joist pinned so they can't move in plan view. The joists have a start and end level offset. When I change the size of these joists they randomly change their offset elevation.
I have had this problem before and don't know if there is a fix to prevent this.
martinTstewart_Adsk
Autodesk Support
Autodesk Support
To give the Revit community here more to go on, could you make an Autodesk Screencast with audio narration-while demonstrating your steps in Revit?  Show the steps your taking, the relevant settings and properties, and the results you're getting. Then post the link to the video here at this Forum post.
How to use Autodesk Screencast to document a support issue
Also, please identify what version and build of Revit you're using. See How to tie the Build number with the Revit update
See also:  Beam Instance Properties
Martin Stewart
AEC Support Specialist
