if i'm understanding you, you want the beams to be joined like the second image, when your z-offset is -2500? Two options i can thing of. First use Start & End Level offset instead of Z, but is suspect you will have the same issue, since your analytical wall is in the wall. Second, put your analytical lines outside the wall.
