Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Beam/Column joints in Structural Framing Beam
1 REPLY 1
manickavasakam_selvam
142 Views, 1 Reply
I connect Beams using the Beam/Column joint comment it connected when it is in 500mm z-offset value, but I increase the Z-offset value its unjointed, I can't connect the beam. How to solve this problem. I placed this beam nearby wall that walls.
Thank you.
1 REPLY 1
if i'm understanding you, you want the beams to be joined like the second image, when your z-offset is -2500? Two options i can thing of. First use Start & End Level offset instead of Z, but is suspect you will have the same issue, since your analytical wall is in the wall. Second, put your analytical lines outside the wall.
Forma Design Contest
Technology Administrators
