Beam Column Connection
revit1980
revit1980
Hi guys,
when I am placing beam,  gap occurs between column and beam. Please help me how can I fix this.
I hereby attached the rvt for your reiview
Regards
jeroen_vanmassenhove
I have taken a look at your revit file.
I have made the gap disappear in two ways:
1. Draw the line a bit away from the column's edge:
2. Dissallow join and then draw to the edge of the column:
Hope this is of any help and a good enough solution for your need.
Kind regards.
revit1980
Thanks for your reply. Where is disallow join command? I don't know where to find it
Regards
Stanis-74
here you can read the rules: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2017/EN...
to disallow join pur right buton of the mouse when the dot is chosen:
revit1980
Thank you Mr. Stanis.
Really appreciated
