Beam and Column Intersection
selmanyesil
selmanyesil
Kindly please help me how can i join this beam and column?
I am getting belo warning
"Highlighted elements are joined but do not intersect."
Selman YEŞİL LinkedinYoutube
A_MAQ
Hi @selmanyesil,
actually this warning is annoying, did you try to remove columns or beams and draw it again ,
try this it may help
best,
Autodesk Expert Elite
selmanyesil
Thank you, I think i found a solution
In family properties dialog when i changed Material for model behaviour as concrete.They are easily connecting each other.
But this time i dont know how to remove this triangular section.
Please help
A_MAQ
Good news
to cut the triangular section use model in place void extrusion or using mass
Best,
selmanyesil
I am sorry I did what you said but i couldnt  solve my problem
 Component > model in place> family catgory structural framing>Void Extursion and got below message
A_MAQ
Actually there are also two ways to do that
-Using opening by face (structural tab/opening/by face)
-using mass same as model in place and it will work for sure (after done you can hide mass from vv)
best,
