I'm trying to add a shear lug to a column base plate steel connection in Revit 2021. The shear lug (or "shear anchor" in the dialog box) needs to be a 1 3/4" x 6" deep x 15" wide plate across a 15" wide base plate. I have that added in without issue. However, the connection also includes a longitudinal plate that would be parallel to my shear load and therefore useless. It still shows up even with the thickness set to zero. If I try zeroing out the width or depth of the unwanted plate, it breaks the entire connection. Any suggestions?
Link copied
