Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
BASE PLATE CONNECTION
7 REPLIES 7
Message 1 of 8
ArmanMargaryan
1867 Views, 7 Replies
How to remove anchor bolt?
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
Linkedin | Facebook
Revit Structure Certified Professional
Labels (2)
7 REPLIES 7
Message 2 of 8
hmunsell
in reply to: ArmanMargaryan
how was it placed?
can you upload the model/family for us to look at?
Howard Munsell
Message 3 of 8
ArmanMargaryan
in reply to: hmunsell
File attached.
Arman Margaryan
Linkedin | Facebook
Message 4 of 8
Hi @ArmanMargaryan
You will need to "Break" the automatic base plate connection, this will seperate out the plate, anchors, welds which will then allow you to delete the one anchor.
Rob Merriman, AEC Technical Lead, Graitec
Message 5 of 8
I created a small video with the steps on how to delete the anchor. You will have to break the custom connection and then break also the Base Plate connection. You can then delete the individual corner anchor and recreate the custom connection from the rest of the steel elements.
https://autode.sk/3iqSpbO
Mihai Sandu
Sr. QA Analyst
Message 6 of 8
Thanks, but I'm looking for another option.
Arman Margaryan
Linkedin | Facebook
Message 7 of 8
From my knowledge there is no other option. This is how you would do it in Advance Steel or Revit Steel Connections. The Standard Connections (e.g. Base plate) let you model a lot of steel connection geometries, but there are some situations in which you can't obtain that using the standard connection. In those situations the only option is to get as close as possible with the standard connection and then Break the connection and do the rest of the changes. Then you can create a custom connection from that specific steel connection geometry.
Mihai Sandu
Sr. QA Analyst
Message 8 of 8
Thanks a lot.
Arman Margaryan
Linkedin | Facebook
