Bar length calculated is reduced. Why?
tobtsheri
tobtsheri
Hello:
I modeled a rebar chair. dimensions a,b,c,d,e are 200mm, 778mm,500mm,778mm,200mm. The reporting  bar length from revit is 2364.5mm. But if you manually add the dimensions, it should come to 2456mm.
The bar length calculated by revit is reduced.
Can any one please help me figure if out? Attached screen shot below
awes
Revit takes into account each bending. A bent corner is shorter than a sharp corner
tobtsheri
Is there any way to calculate and show the total bar length for the sharp corner rather than showing the round corner?
edwin.prakoso
You can create a calculated parameter and add all the rebar lengths.
Cheers,
Edwin Prakoso
tobtsheri
Thank you so much sir. Didn't think about that 🙂
EdwinG
be carefull to add all values.
see pic below (shape M_04)
tobtsheri
Ok. Thank you so much for your reply 🙂
