Automaticaly fil the column "Mark" field with data from the Column "Grid" field
Lets say i want to take the column location (grid Mark) field data and plug it into the "mark" field for the column....how do i do that?
and also my building has 2 floors but ive made the column in such a way that its a single column from the ground level tot the top of the second floor level how do i get the column data by level instead of a single 20 ft column?  ( is this Bad modelling Practice ? )
AGYEMANG.OFOSU
YOU MAY NEED DYNAMO FOR THAT.
RPTHOMAS108
I've written the below document macro for this task, to be manually run each time column positions are changed.
In Macro Manager Create a new Module with language set to VB.Net
Within SharpDevelop environment replace all the text in the 'ThisDocument.vb' window with the code below and compile the project with button below.
Close SharpDevelop and run the macro by either double clicking or selecting it and pressing run.
This code as is adds a level prefix to each column before adding the grid ref. You can prevent this behaviour by changing the line:
Const AddlevelRef As Boolean = True
To
Const AddlevelRef As Boolean = False
If you do this you'll likely get duplicate mark warnings. Unless you plan to detail full building height column lengths (which would be unusual) you'll have to split the columns per floor.
Imports System
Imports Autodesk.Revit.UI
Imports Autodesk.Revit.DB
Imports Autodesk.Revit.UI.Selection
Imports System.Collections.Generic
Imports System.Linq
<Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)> _
<Autodesk.Revit.DB.Macros.AddInId("B0059921-31C9-465D-8A56-08F5780F302A")> _
Partial Public Class ThisDocument
    Private Sub Module_Startup(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Startup
	End Sub
	Private Sub Module_Shutdown(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Shutdown
	End Sub
    Public sub TransferColLocToMark()
		Dim IntDoc As Document =Application.ActiveUIDocument.Document
        Dim FEC As New FilteredElementCollector(IntDoc)
        Dim ECF As New ElementCategoryFilter(BuiltInCategory.OST_StructuralColumns)
        Dim Els As ICollection(Of ElementId) = FEC.WherePasses(ECF).ToElementIds
        Dim GetColLev = Function(Item As Element) As String
                            Dim Lv As Level = TryCast(IntDoc.GetElement(Item.LevelId), Level)
                            If Lv Is Nothing Then Return Nothing Else
                            Dim J As Double = Lv.Elevation
                            Dim P_Base As Parameter = Item.Parameter(BuiltInParameter.FAMILY_BASE_LEVEL_OFFSET_PARAM)
                            If P_Base Is Nothing = False Then
                                J += P_Base.AsDouble
                            If IntDoc.DisplayUnitSystem = DisplayUnit.METRIC Then
                                Dim J_m As Double = J * 0.3048 'ft to m
                                Return J_m.ToString("F1")
                            Else
                                Return J.ToString("F0")
                        End Function
        Dim WKSharing As New List(Of ElementId)
        On Error Resume Next
        Using Tx As New Transaction(IntDoc, "Transfer grid ref to column mark.")
            If Tx.Start = TransactionStatus.Started Then
                For Each item As ElementId In Els
                    If IntDoc.IsWorkshared = True Then
                        Select Case WorksharingUtils.GetModelUpdatesStatus(IntDoc, item)
                            Case Is = ModelUpdatesStatus.DeletedInCentral, ModelUpdatesStatus.UpdatedInCentral
                                WKSharing.Add(item)
                                Continue For
                            Case Else
                        End Select
                        Select Case WorksharingUtils.GetCheckoutStatus(IntDoc, item)
                            Case Is = CheckoutStatus.OwnedByOtherUser
                                WKSharing.Add(item)
                                Continue For
                            Case Else
                        End Select
                    Dim El As Element = IntDoc.GetElement(item)
                    If El Is Nothing Then Continue For Else
                    Dim ColLoc As Parameter = El.Parameter(BuiltInParameter.COLUMN_LOCATION_MARK)
                    If ColLoc Is Nothing Then Continue For Else
                    Dim MK As String = ColLoc.AsString
                    If String.IsNullOrEmpty(MK) = False Then
                        If AddlevelRef = True Then
                            MK = GetColLev(El) & " " & MK
                        Dim P_mk As Parameter = El.Parameter(BuiltInParameter.ALL_MODEL_MARK)
                        If P_mk Is Nothing Then Continue For Else
                        P_mk.Set(MK)
                Next
                Tx.Commit()
        End Using
        If WKSharing.Count <> 0 Then
            TaskDialog.Show("Worksharing", "Some items could no be updated due to worksharing, synchronise and try again.", TaskDialogCommonButtons.Ok)
 End Sub
End Class
