Automate Export to DWG
Message 1 of 11
For coordination with other autocad products on projects I currently export to dwg a set of 3d views to a folder with a prefix  for each of the files created (each view is a different structure in the revit model)
Is there any way to automate this process?
Cheers,
Richard
Replies (10)
Message 2 of 11
L.Maas
This would mean writing an add-in, look for an app or using Dynamo.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 11
Cheers, I figured as much but I would have thought that I'm not the first person to try and achieve this, was hopping there was a method already available. Searching only seems to show methods to automate schedule exports.
I was hoping it would be as simple as using task scheduler to run a script similar to how the navisworks batch exporting works.
Message 4 of 11
awes
How would you like to automate the process
- make a set of views
- export -> dwg
- select set
- select export setup
- next
- select naming: Automatic - Long (Specify prefix)  and ok
Message 5 of 11
Thats pretty much spot on awes, I made the set in the print section and called it 'Plant Coordination Set', the prefix would be 'Revit', the only other thing is trying to path the outputs to a specific folder , at the moment it defaults to my 'Documents' folder on my C: drive
Message 6 of 11
Hi Anders,
Any idea how to automate the process mentioned.
Cheers
Richard
Message 7 of 11
Not sure if there is a question but you can select a folder before exporting to DWG.
Message 8 of 11
Exporting things manually wasnt the question, the question is ... how to automate the process listed
Message 9 of 11
bump
Anyone ???
Message 10 of 11
Hi Rich0,
Have you ever found an answer on how to automate this process? I have  the same issue here, lots of different projects needing to be exported to dwg. I am currently working on scripts to optimize a lot of different tasks but didn't get to this one yet, have you found anything useful?
Selim
Message 11 of 11
No sorry, I got nowhere with this one, I just do it manually
