Announcements
Assigning COBie data to imported Civil 3D geometry
Majoco
Majoco
Hi all,
I'm working on a project where we've done the external works model in Civil 3D, and the actual building is in Revit. The problem we're having is linking in the Civil 3D model into Revit in order to add the relevant COBie data to the pipes/drainage to achieve BIM Level 2.
We're able to link in the C3D file fine, but this essentially comes in as a block import and we're unable to select individual pipes to add COBie data to, it basically comes in as dumb geometry as Revit doesn't know what each pipe is.
Does anyone know if there's a method to do the modelling of U/G services in C3D then link it into Revit in order to assign COBie data to effectively, in order to ultimately generate the COBie spreadsheet? Or is that not an option and you'd advise using Revit to model the external works in the first place?
Cheers,
Not a C3D user but maybe can help. If no direct workflow try exporting to IFC. Use this workflow to get property data in AutoCAD Architecture to a Revit Project. The IFC obects can be scheduled in Revit and custom properties (whg-* in the screenshot) are transferred. Might work for C3D
Majoco
Hi @Anonymous
Ok that's interesting and something i'll have a go at and see what results i get.
I appreciate your response.
Cheers,
Haneenalbow
You can use the COBie extension in Navisworks after you import your Civil 3D model to Navisworks.
RPTHOMAS108
If your deliverable is C3D or Revit and you are expected to add COBie / other data to that prior to federation of model in Navis (by others) then I don't see how the extension helps. Perhaps they say you also have to produce a Navis file with your data in (would you then ordinarily leave it out of other formats). This is usually the issue: who is expected to do what and in which program.
The other issue is often that an organisation is expected to produce one IFC but internally that is made up of two models one from C3D and one from Revit etc. It should be that the part data comes through from C3D when linked into Revit and exported from that as IFC. You can't edit C3D object data in Revit since it is basically a DWG import so need to incorporate it in C3D to start with.
People that create the objects are best placed to classify them not the people that federate models.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
