Asking about revit structure to produce drawing in structure consultant
walidinJKACC
Message 1 of 1
walidinJKACC
Hi, revit expert..!
I'm new learner of revit. I work at structural consultant. As far as this, I use autocad to produce structure consultant drawing. But time by time I'am interested in revit for apllying it.
I have created sample of revit model (with revit 2014).
I attached here, and having SOME QUESTIONS INSIDE EACH FLOOR LEVEL.
revit for structure consultantrevit for structure consultantI attach file Question-Answer.docx too for you to answer if possible, or you can answer directly in revit model, or you can share your answer video if possible.
Thank you
At last,  to everyone who works in a structure consultant, can I have your sample of structure project documentations, that may cotains:
1. Drawing List
2. Standar drawing notes as general notes
3. Foundation plan
4. Foundations details: such as pile detail, pilecap detail.
5. Lower structure detail: such as Ramp, Pit Lift, GWT detail (Ground Water Tank), STP detail (Sewage Treatment Plant)
6. Floor plan 1, 2, 3, ..., etc,
that shows beam dimension, column dimensions, FFL (Finish Floor Level) and SFL (Structure Floor Level), Slab types (thickness and reinforcement) that
sometimes categorized by S1, S2, S3, ect.
7. Beam Reinforcement Plan that shows reinforcement of beams on each level.
8. Roof Plan
9. Building Sections
10. Sections/detail of different level
11. Details of steel join
What i need here is just for comparison only, how revit serve drawing for structure consultant.
Thank you
Replies (0)
