Angle
Angle
mphungDCHNW
Message 1 of 20
Angle
mphungDCHNW
Does anyone know how to change the orientation for angles I've tried changing the reference plan angles etc
I am trying to get my angles like the third screenshot.B.JPGc.JPGbracing.JPG
Replies (19)
Message 2 of 20
Draw it using pick 3D line then grip stretch to the desired length.
Message 3 of 20
mphungDCHNW
Where is the 3D snap option on properties ?
Message 4 of 20
Do you see what I circled in the screenshot?  Here again:
Message 5 of 20
mphungDCHNW
With the 3D snap I am trying to snap to the mid point of a beam but it won't allow me
Message 6 of 20
mphungDCHNW
I have placed a beam although its saying to check the Vg SETTINGS AND PARAMTERERS even though I have all the categories turned on I still can't see it in 3D or in 2D plan.
Message 7 of 20
No.  You already have the green model line so you just need to to use Pick Line tool + 3D snapping box checked to create the L bracing, then grip stretch it to adjust the length if need be.
Message 8 of 20
mphungDCHNW
I know but even if I pick it my angles disappears I had to import a correct angle from another project and copy and paste it into the current project..
Message 9 of 20
You can also draw the angle directly without picking the model line, by change the view to coarse so that you can snap to mid point/endpoint/intersection point of other members more easily.
Message 10 of 20
Sound like something is wrong with your angle family.  Where did you get it from?  Did you load one from the OOTB library?
Message 11 of 20
mphungDCHNW
Loaded it from the angle family within the Revit Library
Message 12 of 20
Maybe you should share your model here because I cannot replicate what you are not being able to do.
Message 13 of 20
mphungDCHNW
As stated I am trying to align my angles to be like the first picture shown. However it is coming vertical up when orientated through the structural brace system  (when creating). Tried doing it regular through the just placing the beam but as a angle and it is no where to be found I've made sure that the category is turned on which it is. I've search through the model but can't find the angle. ]
I have tried your 3D snapping however I still get the same orientation as shown in picture two the only way I resolved my problem was copying a angle from a old project and placing it in my plan view which had the correct orientationbracing.JPGB.JPG.
Message 14 of 20
I need to see a video how you managed to draw the member perpendicular to the line.  Can you at least show a screenshot where you start drawing the member (showing the ribbon and option bar as I showed them)?
Here is what I got using pick line to draw or draw the member directly on the line.
Message 15 of 20
mphungDCHNW
Which method do you want me to screen the brace system one or the beam one ?
Message 16 of 20
Huh?  I don't dictate means and method.  You can use which ever works for you, as along as it captures this screen.
Message 17 of 20
mphungDCHNW
Message 18 of 20
Before you start drawing, reset all of the below to 0.
Message 19 of 20
mphungDCHNW
I have replaced what you said to 0 however the angle still coming in wrong same if I try to create a line its just going to the wrong orientation.
Message 20 of 20
Can you share your Revit model?
