analytical contextual tab missing in revit 2022
MichaelWSullivan
MichaelWSullivan
When I activate the analysis tab in the ribbon the contextual edit tab is missing, I can adjust using keyboard shortcuts but can't finish cancel or save changes. Below is the desired behavior successfully activated in Revit 2020
catalin_lang
"Edit analytical model" menu should appear only when you enable the Analytical Adjust mode: Click Analyze tab catalinlang_0-1651077966798.gif Analytical Model Tools panel catalinlang_1-1651077966799.gifcatalinlang_2-1651077966799.png (Adjust).
Is it a different workflow you are trying?
catalin.lang
MichaelWSullivan
That is the workflow I am using but tab doesn't appear...can't save or cancel
catalin_lang
The only time it happened to me was when I was using 2 monitors. Otherwise, the panel should be there.
I'll try to reproduce it. Any hints would be helpful.
Thanks!
catalin.lang
MichaelWSullivan
I'm using 2 monitors........laptop as CPU and secondary monitor and a Viewsonic as primary. I will try using single monitor to see if this corrects.
MichaelWSullivan
Following up on this......I revisited the project in v2022 and opened an analytical 3d view, closed the laptop to utilize a single monitor and contextual tab reappeared! However if I open laptop and repeat command the tab is not visible, therefore I assume that this is a graphics problem with dual monitors?
MichaelWSullivan
Returning the tab back to the ribbon solves problem of the floating tab disappearing when using multiple monitors.
