analytical automation
leal
leal
In Revit 2023. It is not possible to use Analytical Automation. When I call it for an opened physical model I receive a message about a fatal error and the revit closes. I just finished to download the last upgrade the 2023.1.1.1 Is there anyone that can help me?
Ahmed_Muharram
did you try a simple model to check if its a common issue or not
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
leal
Hi
Yes it is a common issue. It happens for all the models I tried. Ans it happens for REVIT 2023 and REVIT 2024
Ahmed_Muharram
did you try repair the setup of revit
leal
How do I repair the setup for REVIT
Ahmed_Muharram
  1. Click Start menu > Control Panel > Programs > Uninstall/Change.
  2. In the Uninstall or change a program, select the product name, then click Uninstall/Change.
The installation wizard reopens in Maintenance mode.
  1. Select Repair or Reinstall.
  2. On the Repair or Reinstall page, select one of the following options and click Repair or Reinstall to start the process.
  • Repair. This option replaces all registry entries that the product initially installed and restores it to its default state. If you are missing product files, use this option.
  • Reinstall. This option repairs the registry and reinstalls all files from the original installation. Use this option if the Repair option does not solve the problem.
  1. On the Repair/Reinstall Complete page, click Finish.
leal
Hi, thank you for your reply. It is not possible to repair REVIT 2024. I was succed to repair the UNIT SCHEMAS for 2024. It worked but the problem is the same.
My windows is portuguese edition. For REVIT 2023 e 2024 I downloaded the English US language package. The same I did for the AEC package. Is there any incompatibility between English versions for REVT and the WINDOWS 11 Portuguese edition?
