Adding End Codes to members
tmuirHJ7LP
tmuirHJ7LP
I am currently adding end codes to each member in my model on the structural plan views, wondering if there is an option to have the member change colour or show that a symbol or something else that shows that that member has end codes so you can see your progress over the plan on what members have been completed.
jay_colcombe
This would fall under Filter you could create a Filter to show if the End Code has a Value if so you can make it Visible or Turn Off, alternatively you could use a Colour or a Transparency to see those which do or don't have a code.  I have used Comments Parameter as an Example below where one beam has some information in this field the other does not!
Jay Colcombe
Autodesk Certified Instructor
