Adding dimensions on a 3D view
Hello everyone,
I would like to know if it is possible to add 3D views in revit 2018 in a specific sectionbox. I am currently having problems doing that. You can see in the image columns that are over structural footings, my ideia is to measure the elements of the columns.
Best regards.
Not sure if I understand you correctly but you can always set the workplane to a surface or a plane you want to place the dimensions.
Yes I think that is what I am searching. How can I do that?
ennujozlagam
hello, you can try this some sample 3D dimension. thanks
