Adding Brackets to Structural Connection
How can i add brackets to structural connections? is it possible? it's possible to add stiffeners,plates, shims etc so i figured it could be possible to add brackets, i just cant find that option within the connection settings. I'm referring to the highlighted parts on the image.
mihai.sandu
Hi Archext,
If this request is inside Steel Connections for Revit 2017, then you can model the situation using a Moment End Plate connection. The Stiffeners can be created only on the End Plate. They can't be extended to touch the secondary beam's flange.
Please see attached picture with the 2 tabs that control the Stiffener creation.
Mihai Sandu
Sr. QA Analyst
