add dimensions to graphical column schedule
haydenwse
haydenwse
Is there any way to add dimensions to a graphical columns schedule?  I am working on a project that has precast columns which all have a different height and elevations to things like corbels and connections.  It would be nice to dimension some of these items on a graphical column schedule, but I just get a very annoying beep when I try.
mphungDCHNW
The b x h parameters of the column section need to be Shared Parameters...Edit the family and change them to Shared Parameters, then you will be able to schedule and/or tag them in the project
The Height/Length is available in the Structural Column OOTB parameters...Length/Cut Length or can be calculated using Base and top constraints, volume, area.
haydenwse
Without being able to dimension or place detail bubbles on the graphical columns schedule it is totally useless for concrete columns.
You can place detail views  on top of the graphical column schedule on sheet.
