Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
3D Snap
1 REPLY 1
apdim
365 Views, 1 Reply
3D Snap
Hey everyone,
Im trying to place bearings, girders and deck but for now-unsucessful. I have placed pier caps on piers but I set manually offset distance and its not pecise.
I cant snap family to another family.
Also because its litle complicated model-i cant(there is slope) create level for every girder to place it.
I cant select refence plance to place families on them...
How can I do all of this? Thanks!
1 REPLY 1
chauh
in reply to: apdim
You might want to consider a different approach to how you have the elements modeled. If I were to approach this as a single family I would use a structural column family rather than a structural foundation family. This family would be nested with the pile cap and piles in it at their desired location and the upper portion as a more standard column. This would allow you to properly attach it to a plane or structural object of your choice.
Forma Design Contest
