RevitAPI:NewTakeoffFitting
SimonaQQ
1,197 次查看
2 条回复
1 条消息(共 3 条)
SimonaQQ
在学习NewTakeoffFitting这个方法时遇到“no routing preference for takeoff set for this pipetype”错误
  var p = doc.GetElement(selection.PickObject(ObjectType.Element)) as Pipe;
                var line = (p.Location as LocationCurve).Curve as Line;
                var ins = doc.GetElement(selection.PickObject(ObjectType.Element)) as Pipe;
                var pcs = p.ConnectorManager.Connectors.Cast<Connector>().ToList();
                var inscs = ins.ConnectorManager.Connectors.Cast<Connector>().ToList();
                var insc = inscs.OrderBy(t => line.Distance(t.Origin)).FirstOrDefault();
                using (Transaction tra = new Transaction(doc, "aaa"))
                    tra.Start();
                    doc.Create.NewTakeoffFitting(insc, p);
                    tra.Commit();
是哪里出现错误了呢?
0 个赞
已接受的解答 (1)
1,198 次查看
2 条回复
回复 (2)
2 条消息(共 3 条)
BIM.Frankliang
已接受的解答
建议先尝试Revit手动能否连上三通。
3 条消息(共 3 条)
lynn_zhang
您好!请问您的问题解决了吗?是否尝试了以上 @BIM.Frankliang 建议的方法?
Lynn Zhang
0 个赞
