Announcements
Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Yes/no parameter to yes if text parameter is empty
Lennard_Kemper
Lennard_Kemper
Hello, I would like to trigger a YES/NO parameter depending on whether a certain text parameter contains text or not.
But unfortunately I have no idea what the formula for this should look like, or whether it is even possible in this combination.
I hope someone can give me an answer here.
apjones
Have you looked here:
https://www.revitforum.org/forum/revit-all-flavors/tutorials-tips-tricks/1126-revit-formulas-for-eve...
Pete
>Please Accept as Solution and give Kudos as appropriate to further enhance these forums. Thank you!
No you can't use a text parameter to drive other parameters.
