what are these little black filled in circles?
jakeQTGYV
Message 1 of 15
jakeQTGYV
Replies (14)
Message 2 of 15
hmunsell
need more information, it could be any number of different things. Can you select it? What are its properties?
Howard Munsell
Message 3 of 15
jakeQTGYV
I can not select them, this morning I just noticed them. Not sure how to turn them off.
Message 4 of 15
hmunsell
change your discipline to Coordination and see if you can select them.
Howard Munsell
Message 5 of 15
jakeQTGYV
unfortunately that grayed out for me
Message 6 of 15
hmunsell
it is probably being set by a View Template. change your View Template to None and then you can change the discipline.
Howard Munsell
Message 7 of 15
s.borello
Can you tab select them?  I bet they are in a link.
Message 8 of 15
jakeQTGYV
Untitled.pngim kind of able to select them. it selects all of them or the entire model when i try to click one.
Message 9 of 15
jakeQTGYV
it appears to be in the architectural model
Message 10 of 15
hmunsell
when you have the link selected, TAB again on the dot and it should pick it, thru the link. then you can look at the properties and type settings to see what it is.
Howard Munsell
Message 11 of 15
jakeQTGYV
jakeQTGYV_0-1682087912386.pnginteresting it says sprinkler
Message 12 of 15
hmunsell
now that you know it is in the Arch link and its a Sprinkler, you should be able to turn off the category in the link. whether that is thru a View Template or in your VG Overrides.
Howard Munsell
Message 13 of 15
jakeQTGYV
how exactly do i do that? sorry, pretty green.
Message 14 of 15
jakeQTGYV
i know how to open the view template window  but what do i click in here?
Message 15 of 15
hmunsell
The main thing to remember when editing VT's (View Templates) is the check box on the right. only parameters with a check box will be applied. so you can uncheck items that you want users to have the flexibility to change as needed.
see attached video....
Howard Munsell
