What are these errors are saying how to fix them?
narasimhamurthy8ULAN
I am opening a old model in Revit 2022,
I found some errors i want sombody experts to explain what it mean by the error where to check and fixt ,
Any tricks . I am exported the report and have all ekement ID's  I want see how other experts are doing that may save my time.
Error 01-The duct/pipe has been modified to be in the opposite direction causing the connections to be invalid.
Error 02 -The family is connected in a network and can no longer keep the connectivity. Disconnect the family from the network?
Error 03- The References of the highlighted Dimension are no longer parallel.
Error 04-Constraints are not satisfied.
Error 05- Space is not in a properly enclosed region.
Error 06-The family is connected in a network and can no longer keep the connectivity. Disconnect the family from the network?
L.Maas
This happens sometimes. Due to code changes between versions, it happens sometimes that issues arise and cause errors. It usually means checking the model and fix it manually.
It is one of the reasons you will try to keep working in the same Revit version for the whole project. And if you need to upgrade it requires planning and testing.
What sometimes can help, depending on the age of the old model, is to make the upgrade incremental. Meaning not from 2021 to 2024 directly but open and save it in 2021->2022->2023->2024.
Regarding the space issue, this might be the same issue, but also could be that you are missing a linked file.
Louis
Please mention Revit version, especially when uploading Revit files.
