Hello @Anonymous,
Thank you for posting in our Autodesk Community Forums! My name is Stephen, a Revit Specialist, and I will be happy to work on this issue with you.
I understand you are receiving the Error: "Exception has been thrown by the target of an invocation"
What action is triggering this message? Saving the model? Also, are you using Vault? This message can been seen when trying to check-in a file to Vault. If so, please check out This Article for some troubleshooting steps.
If this post has provided you with a solution, please select the "Accept As Solution" button. Otherwise, let me know and I will be happy to continue troubleshooting the issue. Thanks!
Stephen St. Russell
autodesk Technical Support
