Weekly New Knowledge Articles by Support team | Jan 11 -17th, 2023
Knowledge articles written by our Revit support team to resolve the problem on your own. There're a couple of incidents reported, do take a look at them for possible workarounds.
Published Date |
Summary |
Knowledge Article |
Incident Logged |
17-Jan-23 |
The connection of two ducts with an angle of 45 (or other angles) degrees does not work, there is no routing element to this type of connection that works in Revit. |
Cannot join duct with angles different than 90 degrees in Revit |
Yes |
16-Jan-23 |
How to constrain the nested family in a host family to be able to move that parametrically in the properties in the Revit model? |
No |
16-Jan-23 |
Is it possible to map the parameter from the nested family with the parameter in the host family in Revit? |
How to map the parameter from the nested family with the parameter in the host family in Revit? |
No |
16-Jan-23 |
How to show the family property values in the Revit schedule? |
How to show the family parameter value in the schedule in Revit |
No |
16-Jan-23 |
MEP fittings (tee, bend, transition) are too long in Revit. |
No |
16-Jan-23 |
When linking an IFC file export from Advance Steel, some steel elements are displayed with different colour in Revit project |
Steel parts displayed with different color after linking IFC file in Revit project |
No |
13-Jan-23 |
"There has been an unrecoverable error during export..." when trying to export an IFC with Revit property sets in Revit 2022. |
Yes |
13-Jan-23 |
How to disable Hello There window in Revit |
No |
13-Jan-23 |
No response when clicking save Dynamo node in Revit 2023. |
Yes |
13-Jan-23 |
In a Revit project containing a linked Rhino model, the view range is not accurate in plan view. Although the view range is set-up to show a particular floor plan level, other floor plan levels randomly show-up in plan view. |
View range in a plan containing linked Rhino model is not accurate in a Revit project |
Yes |
12-Jan-23 |
Exporting to pdf from Revit turns out grey |
Yes |
12-Jan-23 |
Flex Duct show extra symbols at the end on specific floor plan view in Revit. |
Flex Duct show extra symbols at the end on specific floor plan view in Revit |
Yes |
12-Jan-23 |
Nested detail family is not visible in the elevation view in Revit. |
No |
12-Jan-23 |
The 'Save to new file' function grayed out for some views in Revit. |
'Save to new file' function grayed out for some views in Revit |
No |
11-Jan-23 |
Revit crashes with a Customer Error Report (CER) when trying to open any cloud model. |
Crash with CER occurs when trying to open any cloud model in Revit |
No |
11-Jan-23 |
When creating a DWF from a Revit file in the Hebrew text, parentheses change direction |
Yes |
11-Jan-23 |
When trying to delete or create an elbow in certain pipes it takes a long time in Revit. |
Yes |
11-Jan-23 |
How to work with a georeferenced point cloud in Revit? |
No |
11-Jan-23 |
Is it possible to let systems connect through pipe fittings with multiple system connections in Revit? |
Yes |
11-Jan-23 |
Nested generic annotations in face-based families become mirrored and move relative to the family origin in Revit 2023. |
Yes |
11-Jan-23 |
Users reported that walls are not exported to IFC if option "Split Walls Columns Ducts by Level" used in Revit. |
Walls not exported to IFC if option Split Walls Columns Ducts by Level used in Revit |
Yes |
11-Jan-23 |
Blue dimension help lines does not appear for selected windows/openings in 2D view in Revit |
Dimension help lines does not appear for selected windows/openings in 2D view in Revit |
Yes |
