Announcements
Want to create a single pipe as attached in the pic using sweep option!
AkhildJTZCU
AkhildJTZCU
Hi there,
Want to create a single riser pipe for my project - please find the attached pic.
Earlier I have created using sweep option; that's what I remember.
It would be great if you could help me with solving this query.
RobDraw
That looks more like the vertical pipe is rigid and the parts at the ends are flex pipe but it all could be something like pex pipe.
Rob
AkhildJTZCU
How to draw this one, Can you pelase elaborate the steps please! Thanks in advance
AkhildJTZCU
Hi Rob,
For this one i thought if i could draw the bends alone as revit family and the vertical pipe i can just drw n connect in project.
But the thing i created a bend and added a pipe connector of my required dia at the ends but the size is still 609.
The size is not changing, where can i change the dia
AkhildJTZCU
Screencast attached, need to change that 609 size
