Visibility Parameter working in 3D but not in plan view
fpereiraKRLLW
Observer Observer
fpereiraKRLLW
Observer
Observer
I'm having some issues with a visibility parameter. The element is invisible (as it should) in 3D but still visible in plan views. The visibility parameter seems to not be working in the plan view for some reason.
Would greatly appreciate some feedback on the issue.
L.Maas
You might have a look at THIS thread. It descibes a smilar issue. You might find something that applies to your family.
Louis
Please mention Revit version, especially when uploading Revit files.
fpereiraKRLLW
Observer
Observer
I checked and it didn't really help. I tried building it from scratch and it still happens. Here is the family.
iainsavage
Suggest you investigate fittings by Wavin, they probably do what you want without you having to start from scratch.
fabiosato
I changed the nested family to Pipe Fittings and checked Shared in the properties, which worked as expected.
Fábio Sato
lim.wendy
Hi @fpereiraKRLLW,
Welcome to the forum and thank you for posting. @fabiosato has provided you with the steps to get the visibility parameter to work, so for now I am going to mark this as "Possible Answer." This won't prevent other folks from commenting on this question though in the event other ideas come up!
Remember, marking your posts as having an accepted solution really helps out other forum users that have the same issue – so don’t be shy about marking it as a solution! Accepted solutions get viewed more and help more users find the answer to their problems.
If the solution did not work, you can unmark the post as an accepted solution. To cancel an accepted solution, click the ellipsis menu  > Not the Solution.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
fpereiraKRLLW
Observer
Observer
Thanks @fabiosato it worked brilliantly!
