06:35 PM
Is it possible in the View Range to see from floor to ceiling of an attached Architectural model while only seeing smaller view range of plumbing pipework that passes through a slab?
My issue is that is that if i set the view range to only see from the top of level 1 slab to the underside of the slab i then can't see sanitary fixtures (toilets, handbasins, etc.) on the architectural model.
