view range issue
view range issue
Message 1 of 9
view range issue
above level not visible, beams are inside view rage top and cut level.Capture.JPG
Replies (8)
Message 2 of 9
jeroen_vanmassenhove
As the beams are located above your cut plane, you will not see them since you're looking down from the cut plane to the bottom.
However, you can do 2 things:
Kind regards
Message 3 of 9
chris.kershaw
Change your cut plane to 50mm above the bottom of your steel & you should see both
Message 4 of 9
i changed and try also but i can't see architecture walls means below cut plan because it above beam bottom.
Message 5 of 9
chris.kershaw
Strange that usually shows both steel & walls. as that dose not work then maybe there is something else wrong other than the view range
Message 6 of 9
actual i'm doing sheet view so i want cut line wall level and above beams hidden lines because pipes through beams, wall cut pattern i need because it looks more ritualistic , structural & architecture is linked to my model .
Message 7 of 9
Have you tried the solution I gave you, the one that was in the link? Because, of what I understand now from your explanation, that is what you are looking for.
Message 8 of 9
thank you very much it was solve my problems .
Message 9 of 9
m.voss.alvine
please check "accept solution"
Revit MEP 2015 Certified Professional
Revit Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional
remember to 'accept as solution' if this helped
