Announcements
view range isn't working properly
Gilles.Lagrilliere
Message 1 of 8
Gilles.Lagrilliere
Hello everyone
my view range isn't working as it should be.
I see elements that shouldn't be visible and vica versa. My underlay is set to none and I restarted Revit but it does not help either.
hope you guys can help me out.
See attachment.
Replies (7)
Message 2 of 8
jrobrador19
Hi there,
Is it possible that you are using a ceiling plan instead of a floor plan?
I hope this helps.
Please hit the ACCEPT SOLUTION or LIKE button if my post helped you to solve your problem.
Jerous Obrador
Mechanical Engineer| LinkedIn | Autodesk Certified InstructorRevit Architecture Certified ProfessionalRevit MEP: Mechanical Certified ProfessionalRevit MEP: Electrical Certified ProfessionalInventor Certified Professional | Laguna, Philippines
Win 10 Pro / Dell G7 7590 / i7-9750H / 16GB RAM / NVIDIA GeForce RTX 2060
Message 3 of 8
Gilles.Lagrilliere
Hi
I'm using a floor plan.
Message 4 of 8
iainsavage
It is unlikely that anyone will be able to help with this unless you post the model for examination.
Message 5 of 8
aeidAEEEF
make sure that the elements have the right reference level. I've seen the some elements have an offset of 3000 although they are under floor.
Please mark as a solution if this helps.
Message 6 of 8
Gilles.Lagrilliere
Hi everyone
I found the solution to my problem.
It's not really a solution but i had to restart Revit and everything was back to normal. It had something to do with my links but I don't know what it is.
Message 7 of 8
kyawtUH9BH
Observer
Observer
hi i also have like this issue in one model , can't play view range . if i make new plan view, plan view can play.  but it is not totally solving this issue. I want all of my annotation and tagging too.  and I don't dare to restart the Revit.
Message 8 of 8
iainsavage
"can't play view range"
It sounds like the view range is being controlled by a view template but impossible to say for sure without seeing your model.
