View Model for Waste Water
marco.defina
marco.defina
which is the best way to set the view model to see only the waste water pipe? And vice versa to have a plan with pipe without waste water?
BIM Manager - HVAC and Plumbing designer https://www.autodesk.it/content/dam/autodesk/www/products/responsive-imagery/responsive-badges-compare/2019/navisworks-manage-2019-badge-75x75.pngApp AutoCAD per dispositivi mobili premiumNavisWorks Simulate3ds Max___________________________________________________________________________
Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums.
Hi Marco. Usually what I do is, I create filters for all system pipes like Waste Water Pipes, Sanitary, Gas, Fire, etc. So I can turn ON&OFF. After I create filter, I create View Templates to incorporate my filters and eventually apply to the views.
marco.defina
Ok, that's what i thoughy...But which categories you select on the filter? Only pipe system or all (Pipe, fittings,ecc...)?
Hi Marco see attached image. Try using these settings. Play around with other system types. Use System Classification.
