Valve pressuredrop not reporting
Based on the standard motorized valve family I created attached control valve. My goal is to be able to assign Cv values (or define a psi pressure drop in case of Pressure-independent valves). My goal is to be able to schedule control valves, and also include their pressuredrop in the loss report for pump sizing.
I managed to have the valve "read" the flow of the pipe it is cut into and calculate the presuredrop (In the example screenshot based on Cv-value).
On the screenshot you see it displays the pressuredrop. but for the actual pressuredrop it shows nothing. In the family I did assign the pressuredrop to that parameter. But it doesn't seem to actually.
I'm not sure if the problem is that the two valve connectors are linked, but I tried them not being linked, only one of them assigned the flow and pressuredrop and all other combinations I could think of. I also created a mockup system with the valves between a manifold and a pump. The pipe up and downstream of the valve shows the correct flow.
i noticed that if I enter a pressure value under "Loss EMthod" and "LossMethod Settings" it will show up int he pressure loss report, but won't show up under "Pressuredrop" (in properties). I also don't seem to know how I could take advantage of that and have my parameter be that "specific loss"
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
