Using text parameter on checkbox's formula
aboyacioglu
aboyacioglu
If the value of DW_Protection_Text is DPFH, I want the checkbox for Door Protection Full Height to be selected. However, when I write the formula if(DW_Protection_Text = DPFH, 1 < 2, 2 < 1), it gives the error you see below.
Can text parameters be used in checkbox formulas? What is the correct formula?
Note: The formula if(DW_Protection_Text = "DPFH", 1 < 2, 2 < 1) also does not work.
dtiemeyer
I dont believe it is possible in this arrangement. I've never been able to parse a text parameter and get any results. The only reason to not make DPFH a checkbox itself is if there are multiple possible values (more than just true or false), in which case a small list of checkbox options is generally the way to go because then your if/then statements become tolerable, but more than a handful of possible values makes the resulting required formulas nightmarish.
My other CAD is a Cadillac and I like to Revit to the Max!
aboyacioglu
Yes, I realized this after some research. I created an integer parameter and linked the text to it, but that didn't work either. The data will come from the text parameter; is there no solution for this?
dtiemeyer
Perhaps this workaround, but 'list' is not a type of data supported by parameter values.
How to create parameter drop-down list in Revit
bwieldraaijer
It is possible but not with a just a formula, you can add a lookup table as shown in the image and family i've included in my reply.
You'll need to add a parameter for the lookup table name ('LU' in the image, but could be named however you'd like) as shown.
I hope my explanation makes sense and that this helps!
aboyacioglu
thank you it's helpful
