Revit MEP Forum
Using Filters for hiding and showing more than one pipe at the time,
12 REPLIES 12
Message 1 of 13
2928 Views, 12 Replies
Hello Revit users.
I have 10 "System type " of pipes .  Hot, cold, circulation, spinkler, waste...etc
In my template view , "either section , plan , or 3D" I wanna show only lets say , Hot and Cold pipes.
I created filters for every "Filter:system type ,, equals its type " or not equal to ...
It works if i wanna  show one and hide all the rest , by checking the mark of filter in VV.
Hower I coudn't make it possible to show  two different types together and hide all others
(I can only show one type lets say hot water and hide everything else , and once i check 2 marks of system type lets say HOT and COLD all my pipes disapear) .
Hello Revit users.
12 REPLIES 12
Message 2 of 13
Create one Filter for each type using "Equal to". Do not use "Not equal to". Then you can have any combination of types you want.
Message 3 of 13
in reply to: ToanDN
It works for plan view templates , however for section view new template it does not .
I created new plumbing section template were I wanna hide some other pipes in it .
so I made filters "equal to",  for each system type in the template , however checking  or unchecking them changes nothing in the section view
I'v attached a jpg image for the filters
Message 4 of 13
in reply to: ToanDN
Message 5 of 13
J.Wehmer
J.Wehmer
I renamed all the piping systems to have a prefix, that determines what types of plans they can show on, ex:
D-Cold Water
S-Sanitary Sewer
M-Med Oxygen
F-Natural Gas
SD-Storm Drainage
Next I made a filter that looks to exclude all of the (NOT) system type, in your example if would be pipes of (NOT)Domestic Classification. Then turn off their visibility in the filters. This combined filter make you a Riser-ready view in less than a minute and not have to fuss with a bunch of extra filters.
You can combine any flavor of system types that are in your model to make combined views, that will show/hide any combination you need.
-Please click accept as solution if this answers your question!
D-Cold Water
S-Sanitary Sewer
M-Med Oxygen
F-Natural Gas
SD-Storm Drainage
Message 6 of 13
If you filter with the aid of kind call, you will ought to create fittings for every distinct pipe on your constructing. This could be a dozen or greater and gets actually bulky as you can see this page. If you create systems, and clear out with the aid of device kind and machine name you only need one pipe type and one becoming kind.
Message 7 of 13
Mahmoud.Ziedan
Mahmoud.Ziedan
@Anonymous
Please lookout for the default filters found in the default Revit template.
For instance, when we are talking about ducting there is a default filter system inside VG for supply, return and exhaust. Unfortunately, these filter systems are based on system classification, not system type. In other words, if you created a new system for example fresh air it will be based on supply air so the duct system is fresh air whereas the system classification will remain supply air, and this will make a lot of problems.
So I recommend reviewing all the filter systems especially the default and make sure they are built based on system type, not system classification.
Also, pay attention if there is a filter system that combines hot and cold water usually it is named domestic water so if this is turned off(unchecked) then even if you turned the cold water on(check) it will not be affected.
If this still doesn't solve your issue please upload your project to check it.
Please, if this solved your issue, marked as an answer to help others.:)
Your question got successfully answered? Then just click on the 'Mark as solution' button.
src="https://autodesk.widen.net/content/fbz0l2onhe/png/autodesk-expert-elite-forum-signature-logo.png" >
Mahmoud Zeidan
BIM Manager/Mechanical Engineer
@Anonymous
Mahmoud Zeidan
Message 8 of 13
iainsavage
in reply to: Mahmoud.Ziedan
iainsavage
I generally use system abbreviation.
Message 9 of 13
Mahmoud.Ziedan
Mahmoud.Ziedan
@iainsavage
If you have supply air and fresh air.How can you control the visibility of each based on system abbreviation??
For example, if I want to show the fresh air ducts and turn off the supply ducts.
Mahmoud Zeidan
@iainsavage
Mahmoud Zeidan
Message 10 of 13
iainsavage
iainsavage
2 different systems, 2 different abbreviations. SA and FAI?.
In healthcare etc we might have several different types of extract. General, foul, fume etc. Different systems, different abbreviations.
Am I missing something?
Message 11 of 13
Mahmoud.Ziedan
in reply to: iainsavage
Mahmoud.Ziedan
@iainsavage
Iam sorry I meant system classification....
yes sure for abbreviation it works just fine.
Mahmoud Zeidan
@iainsavage
Mahmoud Zeidan
Message 12 of 13
iainsavage
iainsavage
@Mahmoud.Ziedan Your question did prompt me to ask myself why I do it that way and I think it goes back to when I started with version 2015 - I seem to recall that filtering by system type wasn’t possible then so system abbreviation was used instead and I’m still using the same filters that I setup 6 or 7 years ago - maybe old fashioned now but its still a valid option.
Message 13 of 13
Mahmoud.Ziedan
Mahmoud.Ziedan
@iainsavage
Yes, you are totally right. Also before this, we were not able to duplicate a new system type so we used to rely on the duct types and we used to name the duct family by the system...Revit has really developed a lot.
you and I can figure out how much we were in pain 🙂
Mahmoud Zeidan
@iainsavage
Mahmoud Zeidan
