Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
unable to find revit desktop short cut
I'm installing revit 2019 from Autodesk web site , but after installation , I couldn't find the shortcut icon to start the program .
ennujozlagam
you can try this go to windows control panel > file explorer options > view > click the same and see if helps. thanks
ennujozlagam
another option is go to your search options > type Revit 2019 > right click > select pin to start or copy and drag to your desktop and see if helps .thanks
It will be under the Autodesk folder in your start menu.
