Unable to export from Revit to navisworks
Message 1 of 10
While I am trying to export from Revit to Navis works to .nwc
am getting an error as in the image mentioned below.
while working in some times I would be getting an error as below.
I dont have any disk partation apart from C drive in my PC the momory which currently in my pc is 487GB free of 930GB,
64GB of RAM there in PC, With 4GB graphics 8GB video memory available.
I will be clearing all temp files and collaboration cache and opening the project from BIM360 even though I will be getting the above errors.
Please let me now the solution.
Replies (9)
Message 2 of 10
aleksandr.b
Hello!
Actually, this is problem of RAM, but it is enough in your PC.
Maybe new NWC exporter helps you. Try to install it
Best regards, Aleksandr Barsukov.
Message 3 of 10
I am using Revit 2019.2 version can I get a new navisworks exporter?
is there any link to download it.
Message 4 of 10
aleksandr.b
Yes. Here:
https://www.autodesk.com/products/navisworks/3d-viewers
Message 5 of 10
Thanks for the download link let me install and check and see how it works.
Message 6 of 10
I am installed the latest navis exporter even after it's installed the above-mentioed error not resolved.
still looking for a solution from Autodesk.
Message 7 of 10
aleksandr.b
Maybe you project is very heavy? How many elements are exported?
Message 8 of 10
That I can only tell after export. I am not able to export there is memory error as mentioned above.
The project is heavy I agree but in order to create a clash report, I need all services in the view.
if I off some services I may get the NWC but it will be not considered in my Project it needs to be with all services.
Message 9 of 10
aleksandr.b
Try to close all other programs except Revit and export again. Maybe browsers and something like that spend your RAM.
Message 10 of 10
fabiosato
I would try to open the windows task manager to confirm the memory use.
Another option is to create some 3D views and control what is being shown on each, make them show different  sets of elements, them you can merge them in Navisworks.
Fábio Sato
