Revit MEP Forum
Unable to Change the Ducting Colours in Realistic View
4 REPLIES 4
pmdewi
257 Views, 4 Replies
Hi all, I am still newbie to settings in Revit MEP.
Now I am working in a Revit model created by another office, and they set up the piping colour as blue.
When we are trying to create the interior model and render in Enscape, the exposed blue piping is visible in the rendering, and I am unable to change it.
I have set the object style, visibility graphic, and tried to paint the ducting, but they stay in Blue Colours.
Is there something that I've been missing? Thank you very much
Labels (5)
4 REPLIES 4
iainsavage
in reply to: pmdewi
In Realistic views you will see the pipe material, either the material of the pipe as selected in Segments and Sizes or the overridden material set in the system properties.
pmdewi
in reply to: pmdewi
Hi @iainsavage , thank you much for your reply.
I can see the Duct System material from the system properties, but when I try to change the system material, the "edit type" is greyed out. Do you know why?
Thank you very much
iainsavage
in reply to: pmdewi
Is the ducting in your model or in a linked model?
Could you post some screenshots or upload the model?
pmdewi
in reply to: pmdewi
Hi @iainsavage ,
Sorry I am unable to share the model. However, now it has been solved
In the system browser, It turned out that I can right click at the system name and click "Type Properties" to change the system material.
Thank you very much
Forma Design Contest
Technology Administrators
